As a result, the power of the RF signal is distributed equally and in phase between the second terminal 12c and the fourth terminal 12e. These arrangements allow an IF signal to be generated at the frequency fIF (=fRF−2*fLO) at the third terminal 12d and output through the IF filter circuit 22 during reception, as well as allowing a second harmonic of the LO signal to be generated (at 2*fLO) at the third terminal 12d and output as a transmission signal during transmission.
a primary object of the present invention to provide a relatively simple mixer circuit capable of generating an even harmonic of a received local oscillator signal and further generating an intermediate frequency signal from a received radio frequency signal having a frequency close to the frequency of the even harmonic of the local oscillator signal, and capable of allowing concurrent use of the generated even harmonic of the local oscillator signal and the generated intermediate frequency signal. It is a secondary object of the present invention to provide a radar transceiver using the above simple mixer circuit.
