Library IEEE;
USE IEEE.std_logic_1164.all;
USE IEEE.numeric_std.all;
Entity calculator_test is
end calculator_test;
Architecture test of calculator_test is
component calculator_1 is
Port ( clk : in std_logic; -- clock
Clear, load, add, complement : in std_logic; -- operation signals
Din : in std_logic_vector (15 downto 0); -- input data
Result : out std_logic_vector (15 downto 0)); -- output data
End component;
signal clk_test : std_logic := '0';
signal Clear_test, load_test, add_test, complement_test : std_logic;
signal Din_test, Result_test : std_logic_vector (15 downto 0);
begin
UUT : calculator_1
Port map ( clk => clk_test,
Clear => Clear_test,
load => load_test,
add => add_test,
complement => complement_test,
Din => Din_test,
Result => Result_test);
Testbench_process : process
begin
wait for 0 ns; Clear_test <='1';
assert (Result_test = "0000000000000000") report "Fail Clear" severity error;
wait for 10 ns; load_test <='1';
assert (Result_test = Din_test) report "Fail Laod" severity error;
wait for 10 ns; add_test <='1';
assert (Result_test = "1XXXXXXXXXXXXXXXX") report "Fail Add" severity failure;
wait for 10 ns; complement_test <='1';
assert (Result_test = not Din_test) report "Fail Complement" severity error;
wait for 10 ns;
end process;
end test;
dose the testbench code should be in different file than the main code or both together in the same file?
Library IEEE;
End component;
signal Clear_test, load_test, add_test, complement_test : std_logic := '0';
signal Din_test : std_logic_vector (15 downto 0) := "1111111111111111";
signal Result_test : std_logic_vector (15 downto 0);
Constant clk_period_x : Time := 5 ns;
begin
UUT : calculator_1
Port map ( clk => clk_test, -- Maping The Ports
load => load_test,
add => add_test,
Din => Din_test,
clock_process : process -- Independent Process For Clock Generation
begin
clk_test <= Not(clk_test);
wait for clk_period_x;
end process clock_process;
Testbench_process : process -- Process For Stimuli Generation
begin
wait for 10 ns; Clear_test <='0'; load_test <='1';
wait for 10 ns; load_test <='0'; add_test <='1';
wait for 10 ns; add_test <='0'; complement_test <='1';
end process;
end test;
Library IEEE;
Entity calculator is
End calculator;
Architecture a1 of calculator is
Signal dReg : std_logic_vector (15 downto 0); -- Difining signals to be used inside my process
signal error_flag : std_logic := '0'; -- dReg as a result, error_flag as a carry
Signal final : std_logic_vector (15 downto 0); -- final as a final result
Begin
Process (clk) -- The first process to do the operations
Begin
If (rising_edge (clk)) then
If (clear ='1') then -- if we perform a clean the result(dReg) and
dReg <= "0000000000000000";error_flag <= '0'; -- the carry(error_flag), whold be zeros
elsif error_flag = '0' then
if (load ='1') then
dReg <= Din;
elsif (add ='1') then
dReg <= std_logic_vector(unsigned(dReg)+ unsigned(Din) & error_flag ); -- Using flag & to be able to assign additional bit
elsif (complement='1') then
dReg <= not Din;
--values of dreg and din are converted to unsigned type with unsigned() function.
--the unsigned values are added
--the result is converted to standard logic vector with std_logic_vector() function.
case error_flag is -- This additional case is used to
when '0' => final <= dReg; -- detect when the error_flag is zero
when others => null; -- so there will be a result and in
end case; -- other case NULL
end if;
end if;
end if;
end Process;
Result <= final; -- The Final Result
end a1;
Library IEEE;
component calculator is
End component;
begin
UUT : calculator
load => load_test,
add => add_test,
Din => Din_test,
begin
tb_process : process -- Process For Stimuli Generation
begin
wait for 10 ns; load_test <='0'; complement_test <='1';
wait for 10 ns; complement_test <='0'; add_test <='1';
assert (Result_test <= "1XXXXXXXXXXXXXXXX") report "Fail Add" severity failure;
end process tb_process;
end test;
Library IEEE;
Port (
Result : out std_logic_vector (16 downto 0); -- output data
End calculator;
signal dReg : std_logic_vector (16 downto 0); -- Difining signals to be used inside process
signal final : std_logic_vector (15 downto 0); -- final as a final result
Begin
begin
-- and the carry(error_flag), whold be zeros
error_flag <= '0';
final <= "0000000000000000";
elsif (load ='1') then
final <= Din;
error_flag <= '0';
dReg <= std_logic_vector(unsigned ('0' & final) + unsigned ('0' & Din)); -- Using flag & to be able to assign additional bit
error_flag <= dReg (16);
final <= dReg(15 downto 0);
final <= not Din;
error_flag <= '0';
end if;
end if;
end Process;
Result <= '0' & final;
Result (16) <= error_flag;
-- The Final Result
end a1;
Library IEEE;
Result : out std_logic_vector (16 downto 0)); -- output data
End component;
signal Din_test : std_logic_vector (15 downto 0) := "0001111111110001";
signal Result_test : std_logic_vector (16 downto 0);
begin
UUT : calculator
load => load_test,
add => add_test,
Din => Din_test,
begin
begin
Clear_test <='1' ; wait for 10 ns;
Clear_test <='0' ;
load_test <='1' ;wait for 10 ns;
load_test <='0' ;
complement_test <='1' ; wait for 10 ns;
complement_test <='0' ;
add_test <='1' ; wait for 10 ns;
assert (Result_test (16) <= '1') report "Fail Add" severity failure;
add_test <='0' ;
load_test <='0' ;
end process;
end test;
I didn't not say remove the waits I told you to add after to the assignments to move the edges away from the clock edges.Thanks for your help, Actually i tried the delays (after) it worked for me, but now I am using wait because it is required from me to do it with wait.
No your simulation is applying stimulus that doesn't represent a working design. As you haven't FIXED the problem I was referring to with the after.I modified my code and my test code and everything is working except the add operation
Library IEEE;
Port (
segment1 : out std_logic_vector(6 downto 0):= "0000001"; -- 7 bit decoded output.
segment2 : out std_logic_vector(6 downto 0):= "0000001"; -- 7 bit decoded output.
segment3 : out std_logic_vector(6 downto 0):= "0000001"; -- 7 bit decoded output.
segment4 : out std_logic_vector(6 downto 0):= "0000001"; -- 7 bit decoded output.
segment5 : out std_logic_vector(6 downto 0):= "0000001"); -- 7 bit decoded output.
End calculator;
signal error_flag : std_logic; -- dReg as a result, error_flag as a carry
signal BCD1,BCD2,BCD3,BCD4 : std_logic_vector (3 downto 0); -- Defining signal
signal BCD5 : std_logic;
signal clk1 : std_logic;
signal out1,out2,out3,out4,out5 : std_logic_vector(6 downto 0);
component seg is
port (BCD1,BCD2,BCD3,BCD4 : in std_logic_vector(3 downto 0); -- BCD input
BCD5 : in std_logic;
out1,out2,out3,out4,out5: out std_logic_vector(6 downto 0);
clk1 : in std_logic);
end component;
Begin
Map1 : seg
port map (BCD1 => dReg(3 downto 0), -- Interconnecting ports with signal
out1 => segment1,
BCD2 => dReg(7 downto 4), -- Interconnecting ports with signal
out2 => segment2,
BCD3 => dReg(11 downto 8), -- Interconnecting ports with signal
out3 => segment3,
BCD4 => dReg(15 downto 12), -- Interconnecting ports with signal
out4 => segment4,
BCD5 => dReg(16), -- Interconnecting ports with signal
out5 => segment5,
clk1 => clk);
begin
error_flag <= '0'; -- and the carry(error_flag), whold be zeros
dReg <= "00000000000000000";
elsif (load ='1') then -- the load operation it only performed when error_flag ='0'
if (error_flag <='0') then
dReg <= '0' & Din;
end if;
elsif (add ='1') then -- the add operation it only performed when error_flag ='0'
dReg <= std_logic_vector(unsigned (dReg) + unsigned ('0' & Din));
end if;
elsif (complement='1') then -- the complement operation it only performed when error_flag ='0'
dReg <= '0' & not Din;
end if;
end if;
end if;
end Process;
Result <= dReg; -- The Final Result
proc1 : process (clk1,BCD1)
begin
if (clk1'event and clk1='1') then
case BCD1 is
when "0000"=> out1 <="0000001"; -- '0'
when "0001"=> out1 <="1001111"; -- '1'
when "0010"=> out1 <="0010010"; -- '2'
when "0011"=> out1 <="0000110"; -- '3'
when "0100"=> out1 <="1001100"; -- '4'
when "0101"=> out1 <="0100100"; -- '5'
when "0110"=> out1 <="0100000"; -- '6'
when "0111"=> out1 <="0001111"; -- '7'
when "1000"=> out1 <="0000000"; -- '8'
when "1001"=> out1 <="0000100"; -- '9'
when others=> out1 <="1111010"; -- Display 'r' in other cases.
end case;
if (error_flag ='1') then
out1 <="1111010"; -- Display 'r' in cases of error_flag ='1'
end if;
end if;
end process proc1;
proc2 : process (clk1,BCD2)
begin
case BCD2 is
when "0000"=> out2 <="0000001"; -- '0'
when "0001"=> out2 <="1001111"; -- '1'
when "0010"=> out2 <="0010010"; -- '2'
when "0011"=> out2 <="0000110"; -- '3'
when "0100"=> out2 <="1001100"; -- '4'
when "0101"=> out2 <="0100100"; -- '5'
when "0110"=> out2 <="0100000"; -- '6'
when "0111"=> out2 <="0001111"; -- '7'
when "1000"=> out2 <="0000000"; -- '8'
when "1001"=> out2 <="0000100"; -- '9'
when others=> out2 <="1100010"; -- Display 'o' in other cases.
end case;
out2 <="1100010"; -- Display 'o' in cases of error_flag ='1'
end if;
end if;
end process proc2;
proc3 : process (clk1,BCD3)
begin
case BCD3 is
when "0000"=> out3 <="0000001"; -- '0'
when "0001"=> out3 <="1001111"; -- '1'
when "0010"=> out3 <="0010010"; -- '2'
when "0011"=> out3 <="0000110"; -- '3'
when "0100"=> out3 <="1001100"; -- '4'
when "0101"=> out3 <="0100100"; -- '5'
when "0110"=> out3 <="0100000"; -- '6'
when "0111"=> out3 <="0001111"; -- '7'
when "1000"=> out3 <="0000000"; -- '8'
when "1001"=> out3 <="0000100"; -- '9'
when others=> out3 <="1111010"; -- Display 'r' in other cases.
end case;
out3 <="1111010"; -- Display 'r' in cases of error_flag ='1'
end if;
end if;
end process proc3;
proc4 :process (clk1,BCD4)
begin
case BCD4 is
when "0000"=> out4 <="0000001"; -- '0'
when "0001"=> out4 <="1001111"; -- '1'
when "0010"=> out4 <="0010010"; -- '2'
when "0011"=> out4 <="0000110"; -- '3'
when "0100"=> out4 <="1001100"; -- '4'
when "0101"=> out4 <="0100100"; -- '5'
when "0110"=> out4 <="0100000"; -- '6'
when "0111"=> out4 <="0001111"; -- '7'
when "1000"=> out4 <="0000000"; -- '8'
when "1001"=> out4 <="0000100"; -- '9'
when others=> out4 <="1111010"; -- Display 'r' in other cases.
end case;
out4 <="1111010"; -- Display 'r' in cases of error_flag ='1'
end if;
end if;
end process proc4;
proc5 : process (clk1,BCD5)
begin -- This Segment will not Display
if (clk1'event and clk1='1') then -- any thing but 'E'
case BCD5 is
when '0'=> out5 <="0000001"; -- '0'
when '1'=> out5 <="0110000"; -- Display 'E' in this cases.
when others=> out5 <="0000001"; -- Display '0' in other cases.
end case;
end if;
end process proc5;
end a1;
