Writing Output Txt File to SD Card using spartan 3E
nipperkhan
Newbie level 1
Newbie level 1
Hi, I have spartan 3e kit and I need to save my data as a .txt file into SD card. Is it possible by using spartan 3e or Do I need some interface or something else?
well, you'll need a file system set up on the sd card, and some means to access it. its much easier to use a processor for this as it would be very complex direct from hardware. better just to transmit the data over a uart or similar and let a pc log it.
