xpress_embedo
I am using AT89C51 Micro-Controller to interface it with my Graphical LCD,
Writing works fine, means i had displayed the Images on Graphical LCD, but my requirement is to just high and low a single pixel on graphical lcd...
But i don't know, why it doesn't works. (I am using KS0108 Based Graphical LCD)
This is my connection diagram
The function glcd0108_pixel(1,1,1); will dark the pixel on 1,1 the last one specify the dark and if replaced by zero will produce white pixel..
pls have a look at my code...
and tell me what is the problem..
i am also writing my main part
//Connection Diagram
sbit GLCD_RS = P1^2;
sbit GLCD_RW = P1^3;
sbit GLCD_EN = P1^4;
sbit GLCD_CS1 = P1^0;
sbit GLCD_CS2 = P1^1;
sbit GLCD_RST = P1^5;
sfr GLCD_DATA = 0xA0;
//These are two macros definition for setting and clearing a single bit
#define bit_set(var,bitno) ((var) |= 1<<(bitno))
#define bit_clear(var,bitno) ((var) &= ~(1<<(bitno)))
void delay_small()
unsigned char counter;
for(counter=0;counter<8;counter++);
void GLCD_PULSE()
GLCD_EN = 1;
delay_small();
GLCD_EN = 0;
void CHIP_LEFT()
GLCD_CS1 = 1;
GLCD_CS2 = 0;
void CHIP_RIGHT()
GLCD_CS1 = 0;
GLCD_CS2 = 1;
//Write Function
void glcd0108_write(unsigned char c)
GLCD_RW = 0; //Clear for Writing the Data
GLCD_DATA = c;
GLCD_PULSE();
unsigned char glcd0108_read(bit side)
unsigned char lcd_data;
//Set GLCD Data Pins as Input Pin
GLCD_DATA = 0xFF;
GLCD_RW = 1; //Set the RW pin for Reading Purpose
GLCD_RS = 1; //Read Datasheet for Reading Purpose RS and RW pin must be High
CHIP_LEFT();
//Left Side Selected By Default
if(side == 1)
//Select Right Side
CHIP_RIGHT(); //Right Side Selected
delay_small(); //Give Some Delay
GLCD_EN = 1; //GLCD_EN --> High
delay_small();
lcd_data = GLCD_DATA; //Get the data from the GLCD Data Pins
GLCD_EN = 0; //GLCD_EN --> Low
//Reset The Chip Select Lines
GLCD_CS1 = 1;
GLCD_CS2 = 1;
return lcd_data;
void glcd0108_pixel(unsigned char x,unsigned char y,bit color)
bit side;
//Set Side to Chip Left First
CHIP_LEFT();
side = 0; //Initially Set Side = 0
//if the value of x exceed the 63 then select Chip Right
if(x > 63)
x = x - 64;
CHIP_RIGHT();
side = 1;
//Right Chip Selected
GLCD_RS = 0; //Setting LCD Controller for Instruction
//Clear the MSB part of the Instruction Code
bit_clear(x,7);
//Set bit 6 also the part of Instruction Code
bit_set(x,6);
glcd0108_write(x); //Set the Horizontal Address
glcd0108_write( (y/8 & 0xBF) | 0xB8); //Set the Vertical Page Address
GLCD_RS = 1; //Setting LCD Controller for Data
lcd_data = glcd0108_read(side); //Based on the above value of side read the Graphical LCD
//Need two reads to get data
if(color == 1)
bit_set(lcd_data, (y%8)); //Turn on the Pixel
else
bit_clear(lcd_data, (y%8)); //Turn off the Pixel
GLCD_RS = 0; //Set for Instruction
CHIP_LEFT();
if(side == 1)
CHIP_RIGHT();
glcd0108_write(x);
GLCD_RS = 1; //Set for data
glcd0108_write(lcd_data);
void main()
int i;
P3 = 0x00;
P0 = 0x00;
P1 = 0x00;
P2 = 0x00;
glcd0108_init();
delay_ms(1);
glcd0108_clear(); //Clears the Display
P3 = glcd0108_read(0);
while(1);
