Writing a Test Case for which i havent developed
amnandu
Member level 2
Member level 2
Hello friends
I am in a tricky situation. I have been given an assignment to write test cases for a unit which logs the data and sends the packets of data to the server. It has 14 I/O , CAN connectivity to other components on the unit with different speeds, GPS and GSM connections.
Am stuck over here.. Where to start and how?
Till now i started testing using black box testing where i just started doing a pre-test like changing of voltages, giving variable inputs and checking for expected outputs..
Help appreciated.
Regards
Nanda
Thank you for the reply.
Integration test would be better , as i want to test for it function and then the reliability of the unit. Please help me how and where to start?
Regards
Nanda
