I am doing a project where I need to give some freuquency values from a signal generator into an ADC and the output from this ADC, after being passed through window and FFT are being shown in a LCD display on a vertex 5 FPGA board. The problem is the LCD I currently have can only support 4-bit mode but my output is 5-bit mode. I decided to write a code to generate values and instead of seeing them on the LCD I will make a text file and write the results into that file.
Can anyone tell me how can I write a code in verilog which will allow me to give a particular frequency so that I can by-pass the use of signal generator and input various frequency values in the code and get different results?
Thanks
