write read low resolution bmp file from/to flash memory
garfield
Member level 1
Member level 1
Hi
Anyone help me with some guidelines about how to read a bmp file from pc hard disk , then write / read it from / to flash memory.
Regards
<font size=-1>[ This Message was edited by: garfield on 2001-11-17 14:59 ]</font>
In my opinion,you can use a DSP and a flash to build a system.Then you can use C language to make a program.There is "file reading/writing" function in C language.
Use hex loader by Keil,
Write the code in plain c to display your BMP file then convert to hex and load it thorough memmory maker or any flash programmer with data clocking in at rise edge
I had done it 100%
