nabla101
Junior Member level 3
Hi, what exactly is a wrapper file? I keep reading that to do certain things I will need to create a wrapper file "around my code".
I have a rough idea, but not exact...
So a vhdl file *.vhd is just a file containing the vhdl code, just as a *.c file is a file containing c code.
An edif file is a netlist listing the instances of vhdl modules in a design, the attributes of each instance, and a list of nets, showing how the ports of each instance are connected.
A wrapper is a "black box" listing only the inputs and outputs of a device or groups of devices, with no description of the device operation or connectedness?
So I could create a load of vhdl modules and have a load of *.vhd files. Then I could synthesise them and generate an EDIF file for how they are connected together. Then I could create a wrapper file containing all the modules?
Could someone explain if this is right or not, and how the different files are used and related?
