Resistanceisfutile
Member level 4
- Joined
- Aug 22, 2012
- Messages
- 77
- Helped
- 2
- Reputation
- 4
- Reaction score
- 1
- Trophy points
- 1,288
- Activity points
- 2,008
The "opradio" from Arron Cake's site has a few errors:
1) A lousy old 741 opamp DOES NOT WORK when its inputs are within a few voltage from ground. One input is at ground and the other input is almost at ground. The inputs should be biased at half the supply voltage.
2) The detector diode needs a DC load (a resistor to ground at its output).
3) The detector diode needs an RF filter capacitor to ground at its output.
4) The opamp is inverting with an extremely low input impedance that shorts the tuned circuit. The opamp should be non-inverting with a high input impedance.
5) The supply voltage needs a filter capacitor to ground.
I fixed the horrible circuit about 10 years ago:
