worst case corners definitions
Junus2012
Advanced Member level 5
Italy
Dear friends
I am simulating my circuit with worst corners
the worst corners defined in my technology ar
wp = worst case power = fast NMOS & fast PMOS
ws = worst case speed = s slow NMOS & slow PMOS
wo = worst case one = fast NMOS & slow PMOS
wz = worst case zero = slow NMOS & fast PMOS
kindly what is the meaning of fast and slow ????
I have also second question
if I am using the monticarlo simulation, how much percent of the right value should be in order to say that the design is ok ??
Thank you in advance
fast means higher threshold voltage and slow lower threshold voltage
monte carlo... upto 3 sigma
so faster and slower only related to the Vth ??????
if iti is like that then simulating the design with corner analyses will not cover the parameter variability in the wafer, and hence it is not trust method to predict the success the design practically
Just the other way round, Emma! Lower Vth means faster switching on, resp. larger Id.
±3σ means 99.7% , s. the Gauss' standard distribution. Scroll down to "Standard deviation and tolerance intervals" and see the text below the blue curve.
Essentially, yes. For process variations, you have more parameter variations which affect the speed corners, like, e.g. tox.
... simulating the design with corner analyses will not cover the parameter variability in the wafer, and hence it is not trust method to predict the success the design practically
That's why fabs/foundries (should) provide different MC variation sets for mismatch (one wafer only) and for process (all wafers).
But Erikl, I am working with SOI technology from XFAB and they only provided me those corners models. and I was thinking that if the design passed theses corners it is somehow comparable to 99% of monecarlo until you told me the truth .... I am now a little sad
... I was thinking that if the design passed theses corners it is somehow comparable to 99% of monecarlo
May be you actually got the process parameter variation set (i.e. the variations over many wafers). And perhaps the mismatch variations are already included? Ask them!
And a ±3sigma parameter variation MC success means >99% good chips.
You can expect that the performance spread over process corners is similar to +-3sigma process MC spread if your circuit is a standard logic gate. That's because the speed of logic depends on maximum Idsat and the process corners were created to show the extreme values of Idsat.
Whereas if your circuit performance depends on analog small signal parameters such as rds, Cgs, ... then you may see a large difference between process MC and process corner run.
Secondly, process corners do not contain correlation information. You can mix corners of resistors, BJT and MOS at will; but many of these mixed corner combinations are physically impossible and useless to simulate. Process MC instead allows to correlate devices. So, if your circuit contains HVT and LVT MOS and/or moscaps, then again process corner run and process MC run may return very different results.
This is not related to local MC (mismatch MC). You can mix local MC with process corner, or can mix local MC with process MC.
I am simulating an analog circuit
