Eng.Wad
Member level 2
Hi everyone,
I designed the attached circuit for push ON/OFF led control. I did the PCB but didn't work. I tried a simple led flashing on the same pcb, but didn't work, except if it happens to ON without blinking. I did anther try using the bread board, the led will blink when I keep my finger attached to the wire going to OSC2.
I'm using PIC18F2520, I configured the bits as follows:
The code is working on proteus just fine.
There might be something wrong with my configuration or cct or both :-(
Please see the attached image
#pragma config OSC = HS
#pragma config PWRT = OFF
#pragma config MCLRE = ON
#pragma config PBADEN = OFF
#pragma config LVP = OFF
#pragma config WDT = OFF,DEBUG=OFF
