working of External Interrupt0 of PIC18F4550
phoenix prasanna
Newbie level 6
Newbie level 6
Hello everyone,I am learning PIC uc interrupts in which LEDs should glow as output on reception of each falling edge signal on INT0(pin RB0 of PIC18F4550) but LEDs are not toggling when button is pressed.My code and sim is attached below hope you can help me out.
  • Interrupts.rar
void interrupt()              // Interrupt ISR
    LATD=~LATD;               // Invert (Toggle) the value at PortD
    Delay_ms(500);           // Delay for 1 sec
    INTCON.INT0IF=0;          // Clear the interrupt 0 flag
ud23 : Thanks for your kind help,but still not working. :(
Algorithm which i used is mentioned in prog according to which PORTD o/p should toggle but not quite getting it but when i reset ckt it starts toggling in infinite loop.
Before while(1) loop set ADCONx register so that all pins are configured as digital IO.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
//Program to depict the working of External Interrupt0 of PIC18F4550
void interrupt() {
    if(INTCON.INT0IF) {
        LATD = ~LATD;
        INT0IF_bit = 0;
void main() {
    TRISB = 0x01;
    PORTB = 0x00;
    LATB = 0x00;
    TRISD = 0x00;
    PORTD = 0x00;
    LATD = 0x00;
    INTCON = 0x10;
    INTCON2 = 0;
    INTCON.GIE = 1;
    INTCON.PEIE = 1;
    LATD = 0xAA;
    while(1) {
Configure ADCON1 register.
Thank you for your good suggestion.The prog needed to confg ADC and set RB0/AN12 inorder to take i/p but haven't used PORTx to store value still it worked.
ADCON1=0x03;                             // Make RB0/AN12 pin as analog pin (Other pins remain to be digital I/O)
    ADCON0=0x0C;                             // Select Channel0 & ADC off
    ADCON2=0x8A;                             // Left justified, 2TAD acquiciation time, Fosc/32 clock option
    ADCON0.ADON=1;                           //Enable ADC
INT0IE bit is set Enable(=1) by INTCON =0x10, as INT0IE bit is 00010000b which is equivalent to 10h.
