I didn't "Actually" used this module but other related Wiznet Products.i want to hear from someone who actually used .
Check your values if you are able register.. Likeit says after putting value in SHAR ,GWR, SUBR,SIPR . will it actually in nework ?
yogita said:yes i am using 89c51rd2 with Keil. i am using SPI interface . i have done the communication . i can read /write chip.
so ..... u r saying i have to write code for DHCP client . so that DHCP will give the IP addresse ? cant it be any simpler way ( like i have read that we can give reserved IP & MAC to module which should already enterd into DHCP's client list)or tell me the detailed algorithm to write code . programmes on Wiznet are tooo tuf i cant understand them. Thanks a lot for help
