vamsee
Full Member level 1
Hi all!!
I am using data acquisition, in which it has D25 as output and D15 port as input.. the D25 is connected to the PC thru the cabel.. I am using 3 pin hall sensor, the output of it should be connected to the pin8 of the D15.
Now my question, is tat possible to connect directly to the port... (inserting hall sensor output pin in the output port of the D15)??
the attached pic shows the wiring of someother kind as I need the same way wiring.. how did they wired as shown in the pic?
