Victor43
Member level 2
- Joined
- Aug 31, 2011
- Messages
- 43
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Activity points
- 1,754
Dear Readers.
I am interested to learn what factors influence transmission distance indoors where there are obstructions between transmitter and receiver. We have one project where we need to install a few wireless video cameras inside an old four story building. The distance between transmitter and receiver is about 100m. However there are several walls and floors made of concrete between transmitter and receiver. What role does the Transmit Power Output of the transmitter play ? Higher the better ? Also same for the antenna for the receiver ? The antennas for the transmitter will be omni directional. To the best of my knowledge the communication will be PTMT where we will have more then one monitoring station for the same set of video cameras. The highest TPO permitted which can use be used for the 1.5GHz band is 4W or 4000mw. What about using a repeater to achieve the distance we need ? We may have multi receivers hence the reason for omni directional transmitter antenna. Please note that these wireless video cameras have a small footprint and the transmitter will have its own PCB but enclosed in the same housing as of the camera so not separate.
Any comments or suggestions are welcome. Thanking you
Victor
Victor
