[SOLVED] wireless thermometer using RF Tx & Rx. help!
swtbbert
Newbie level 5
Hi!
I've designed a thermometer using RF by pic16f877a, my problem is how con i read the value to the second pic and to display it, please some1 can help..
my codes for TX
// LCD module connections
sbit LCD_RS at RB2_bit;    // rs connection at rb2
sbit LCD_EN at RB3_bit;    // en connection at rb3
sbit LCD_D4 at RB4_bit;    // d4 connection at rb4
sbit LCD_D5 at RB5_bit;    // d5 connection at rb5
sbit LCD_D6 at RB6_bit;    // d6 connection at rb6
sbit LCD_D7 at RB7_bit;    // d7 connection at rb7
sbit LCD_RS_Direction at TRISB2_bit;    // data direction setting
sbit LCD_EN_Direction at TRISB3_bit;    // data direction setting
sbit LCD_D4_Direction at TRISB4_bit;    // data direction setting
sbit LCD_D5_Direction at TRISB5_bit;    // data direction setting
sbit LCD_D6_Direction at TRISB6_bit;    // data direction setting
sbit LCD_D7_Direction at TRISB7_bit;    // data direction setting
// End LCD module connections
float volt,temp;                  // VARIABLE FOR READING AND STORING VALUES
unsigned char   volt_char[15];    // STRING (ARRAY OF CHARACTERS) VARIABLE FOR LCD DISPLAY
void init() // initialization routine definition (register initializations are done here)
 adcon1=0   ;    // configure all portA and portE chanels as analog
 trisc=0x00;
 portc=0;
 trise = 0x2;
 cmcon = 7;
 lcd_init() ;    // initialize lcd connections
 lcd_cmd(_lcd_clear)     ;// clear lcd
 lcd_cmd(_lcd_cursor_off);// turne off hte cursor
void main() // main routine definition
 init();    // call the initialization routine
 lcd_out(1,3,"Temperature"); // show <voltmeter> on 3rd column of first row of lcd
 lcd_chr(2,12,223);
 lcd_out(2,13,"C");        // show <V> on 15th column of 2nd row of lcd
 uart1_Init(9600);
 delay_ms(100);
 while(1)   // step into infinite loop
    volt=adc_read(2); // take the analog signal value fron analog channel 2 (latched to ra2 pin)
    volt=volt/1024;   // extracting voltage value from 10 bit resolution
    volt=volt*5000;   // extracting voltage value from 10 bit resolution
    temp=volt/10;     // CONVERTING THE VOLTAGE VALUE TO CENTIGRADE SCALE
    floattostr(temp,volt_char);// convert the voltage value to string for
                                  //showing on lcd
    lcd_out(2,4,volt_char);    // show the string (voltage value) on
                                  //lcd(2nd row,1st column)
    uart1_Write_Text(volt_char);
    UART1_Write(10);
    UART1_Write(13);
    delay_ms(200);
for RX
char txt;
char uart_rd;
float volt, temp;
 uart1_Init(4800);
 delay_ms(100);
 cmcon = 7;
 trisc = 0x00;
 portc = 0;
 lcd_out(1,3,"Temperature"); // show <temperature> on 3rd column of first row of
 lcd_chr(2,12,223);
 lcd_out(2,13,"C");        // show <C> on 13th column of 2nd row of lcd
do
if(uart1_Data_Ready()){
 uart_rd = uart1_Read();
 ByteToStr(uart_rd,volt_char);
 uart1_Write(volt_char);
}while(1);
Try these codes.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
//Tx Code
float volt, temp;
unsigned char volt_char[23];
void Init(){
    TRISB = 0x00;
    PORTB = 0x00;
    TRISC = 0x80;
    PORTC = 0x00;
    TRISE = 0x02;
    ADCON1 = 0x00;
    CMCON = 0x07;
    LCD_Init() ;
    LCD_Cmd(_LCD_CLEAR);
    LCD_Cmd(_LCD_CURSOR_OFF);
    LCD_Out(1, 4, "Temperature");
void main(){
    unsigned char i;
    Init();
    UART1_Init(9600);
    Delay_ms(100);
    while(1){
            volt = ((adc_read(2) * 500) / 1023);
            FloatToStr(volt, volt_char);
                LCD_Out(2, 4, volt_char);
            LCD_Chr(2, 12, 223);
            LCD_Out(2, 13, "C");
        i = 0;
        while(volt_char[i++]);
            volt_char[i] = ' ';
            volt_char[i + 1] = 223;
            volt_char[i + 2] = 'C';
            volt_char[i + 3] = '\r';
            volt_char[i + 4] = '\n';
            volt_char[i + 5] = '\0';
            UART1_Write_Text(volt_char);
            UART1_Write(10);
            UART1_Write(13);
            Delay_ms(500);
//RX Code
float volt, temp;
void Init(){
    TRISB = 0x00;
    PORTB = 0x00;
    TRISC = 0x80;
    PORTC = 0x00;
    TRISE = 0x02;
    ADCON1 = 0x00;
    CMCON = 0x07;
    LCD_Init() ;
void main(){
    unsigned char i;
    Init();
    UART1_Init(9600);
    Delay_ms(100);
    while(1){
        if(UART1_Data_Ready()){
            UART1_Read_Text(volt_char, "\r\n", 17);
            UART1_Write(volt_char);
            i = 0;
            while(volt_char[i] != ' ');
            volt_char[i] = '\0';
            LCD_Out(2, 1, volt_char);
Re: wireless thermometer using RF Tx &amp; Rx. help!
Thenx, but at receiver the value doesn't appear on lcd
Thenx, it work on transmitter but not on receiver...
In receiver there was a typo. Use this in receiver code.
Code C - [expand]
while(volt_char[i++] != ' ');
If it still doesn't work then use these codes.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
//Tx Code
float volt, temp;
void Init(){
    TRISB = 0x00;
    PORTB = 0x00;
    TRISC = 0x80;
    PORTC = 0x00;
    TRISE = 0x02;
    ADCON1 = 0x00;
    CMCON = 0x07;
    LCD_Init() ;
void main(){
    unsigned char i;
    Init();
    UART1_Init(9600);
    Delay_ms(2000);
    while(1){
        i = 0;
            volt_char[i] = ' ';
            Delay_ms(500);
//RX Code
float volt, temp;
void Init(){
    TRISB = 0x00;
    PORTB = 0x00;
    TRISC = 0x80;
    PORTC = 0x00;
    TRISE = 0x02;
    ADCON1 = 0x00;
    CMCON = 0x07;
    LCD_Init() ;
void main(){
    unsigned char i;
    Init();
    UART1_Init(9600);
    Delay_ms(100);
    while(1){
        while(!UART1_Data_Ready());
        i = 0;
It still not responding, may be my circuit has problem.
My code works. I will test it if you zip and send me your mikroC Tx and Rx project files and Proteus .dsn file. I don't have Proteus 8 so, only Proteus 7.x file. In Proteus the LCD power pins have wrong connections. You have to connect VDD to +5V and VSS to GND but that doesn't make any difference in Proteus simulation.
that is my project
  • Tets Temp.rar
You didn't attach the Proteus file.
Edit: Debug and see why UART is not displaying degree character and 'C'.
  • RF.rar
thank you it is working.
