trf-2.4g transceiver
Hi emavil,
This is a good choice: "2.4Ghz. Data Transceiver"
TRF-2.4G High frequency Transceiver module (GFSK) 2.4GHz
TLP2.4G - High Speed Data/Transceiver 2.4Ghz
Specification :
* Frequency : 2.4~2.524 GHz
* Modulation type: GFSK
* Op. Voltage: 3V
* Output Power: +4dBm
* Data Rate: 1Mbps
* Small footprint size: 20.0 x 36.7 x 2.4mm
* Operating Tempeature: -40 ~ +85 C
* Long range : 280mts @250Kbps ; 150mts @1Mbps
* Built-in antenna.
* Real full-duplex, including decoder, encoder and data buffer.
* Very low cost
* Applications: Telemetry, Wireless Toys, Remote Control, Wireless Speaker, Wireless Earphone or Walkie-Talkie, Wireless Mouse and Keyboard, Utility Meters Data Downloading ...etc
Symbol Parameter(condition) Notes Min. Typ. Max. Units
VDD Supply voltage 1.9 3.0 3.6 V
TEMP Operating temperature -40 +27 +85 Centigrate
f op Operting frequency 1) 2400 2524 MHz
R GFSK Data rate direct mode 3) 250 1000 kbps
F CHANNEL Channel spacing 1 MHz
I VDD Supply current one channel 250kbps 18 mA
I VDD Supply current one channel 1000kbps 19 mA
I VDD Supply current two channels 250kbps 23 mA
I VDD Supply current two channels 1000kbps 25 mA
RX SENS Sensitivity at 0.1%BER(@250kbps) -90 dB
RX SENS Sensitivity at 0.1%BER(@1000kbps) -80 dB
Conditions: VDD=+3V,VSS=0V,T A =-40 centigrade to +85 centigrade
Added after 23 minutes:
This is the complete TRF-2.4G Transceiver Data Sheet.
High frequency 2.4G Wireless Transceiver Antenna, Codec and CRC built in Data Rate up to 1Mbps.
