wireless remote controlled robot without using microcontroller
ssatyaki
Member level 1
can you please tell me any other way of making a wireless remote controlled robot without using microcontroller??
thanks
rf modules and DTMF can be used. Some sort of digital circuit must be designed.
First me all you need to make a truth table and then you can make a expression, and circuit.
    V
You could use an Encoder/Decoder Pair along with a RF TX/RX Pair, there are several Encoder/Decoders available which would fulfill your requirements. Holtek Semiconductor, for example, manufactures the HT-12E and HT-12D, the project below demonstrates their use with a RF ASK TX/RX Pair:
BigDog
Reactions: Nixa
    V
    Nixa
thanks bigdogguru...but does this HT12E & HT12D chips actually convert the PWN by the reciever to digital signal???
Basically, the HT-12E/D pair transmit and receive 4-bits or 16 unique states. Similar encoder/decoder pairs are used to control RC Vehicles, Robots, etc. There are other encoder/decoder pairs available which offer more states or bits if your application requires them. However, 16 states provides quite a few options for your robot, e.g., forward, backward, left, right, etc. And of course all without the use of a MCU.
BigDog
Radio Remote Control using DTMF Circuit
