Maverickmax
Advanced Member level 1
wireless energy transfer experiment circuit
Hi
I have been experimenting it for a while. So I managed to generate 5V 45kHz square waveform using 555 timer with MOSFET transistor. I connect an insulated copper wire coils on drain of mosfet (I never count the number of turns). This is regarded as primary coil.
I produced more number of turns greater with ferrite rod. This would be a secondary coils. The output of secondary coil wire is connected to a diode in attempt to obtain DC voltage. So far I managed to obtain between 0.5 to 1.0V. This is not enough as I am aiming for at least 3 to 5V.
I tried to increase the number of turns in the secondary coil but no significant improvement. Any suggestion??
Is there any calculation or formula allow me to improve my experiment?
MM
Hi
MM
