Wire_load_model in different levels of hierarchy
alexhugo
Junior Member level 3
I have few RTL codes (module A,B,C and D) instantiated in a top level module (TOP). TOP instantiates A, B, C and D and has also some glue logic. Size of A, B and C are between 25K to 50 K.
TOP (A+B+C+D+GLUE logic) is about 200K.
Which of the followings I should do?
Should I do this:
set current_design TOP
set_wire_load_model -name "TSMC_200K_MODEL"
Or this:
set current_design A
set_wire_load_model -name "TSMC_25K_TO_50K_MODEL"
set current_design B
set current_design C
set current_design D
I don't know know if this is going to help but my library is tcbn45gsbwpwc.
Thanks in advance for the help
Alex
second method is best because it has all the information of the all the hierarchy.
you need refer to wire_load_mode (not model )
