neazoi
Advanced Member level 6
Hello,
I have found this antenna
https://www.hamuniverse.com/k4iwlnewwindom.html
I have previously made a 4:1 balun (200R to 50R balun)
**broken link removed** but this is of the Guanella type.
Can I use this balun with this antenna?
Can I also use another coaxial for the feeder instead of RG58? I have
RG223 (double shield) and aircom plus, both expensive cables. Will these
do or it has to be the specific cable to radiate?
Finally, I see that the line isolator is just a turn inside the beads.
Can I just pass the beads around the coaxial and keep them somehow
(tape, tie wraps etc) at the correct point, instead of looping the wire?
