Why X'sistor Are Active Device?
konarkk
Full Member level 2
Mumbai , India
Why X'sistor and Diode are Consider AS Active Device
Active Devices are components that are capable of controlling voltages or currents and can create a switching action in the circuit. In other words, "Devices with smarts!" Examples are Diodes, Transistors and Integrated circuits.
A Passive Device is one that contributes no power gain (amplification) to a circuit or system. It has no control action and does not require any input other than a signal to perform its function. In other words, "A components with no brains!" Examples are Resistors, Capactitors and Inductors .
Ciao,
Shiva
Active devices have in general non-linear current-voltage characteristics, while passive only linear. Diodes are an example of highly nonlinear I-V devices. X'sitor, I've never heard about
saruman1983 said:
....... X'sitor, I've never heard about
Me too.
I can imagine that a TRANSISTOR was ment.
Therefore: SARUMAN 1983, are you really to lazy to write the complete word ?
Don´t forget, also some older engineers participate in this forum who are not familiar with these bloody/silly abbreviations.
Thankx
But I wanna To know that What cause this Device to provide a energy...
Is It a recombination Process Or Current Gain.....
Added after 2 minutes:
or Other Cause
I thought active devices should have power gain and from that point of view, diodes should be left out. I am not sure if it is a subject of classic dicussion with out any convincing result?
Regards,
Laktronics
What about diode...........? it doesn't provide any gain.
And it's considered as a passive device.
Active devices have the ability to electrically control electron flow.
konarkk said:
Thankx
or Other Cause
Active devices such as transistors and diodes doesn't provide any energy.
The larger output power just comes fron the bias power (Vcc, Vdd, etc).
In case of BJT, the large output current/power is controlled by a very much lower current in its base. That power/current simply comes from the bias...:|
