If you don't assign any parameter, it is not necessary to compile a pcell. Since you compile pcell(parameterized cell), you are sure to assign some parameters -- such as gate width, gate length etc.
Tools - > Pcell
then "pcell" menu appears. Clock "Pcell" menu, select the pull-down menu to assign your parameters.
