hi,
Signals are converted from time or space domain to the frequency domain usually through the Fourier transform. The Fourier transform converts the signal information to a magnitude and phase component of each frequency. Often the Fourier transform is converted to the power spectrum, which is the magnitude of each frequency component squared.
The most common purpose for analysis of signals in the frequency domain is analysis of signal properties.
It is remarkably useful to analyze the frequency spectrum of a signal. This technique is applicable to all signals, both continuous and discrete. For instance, if a signal is passed through an LTI system, the frequency spectrum of the resulting output signal is the product of the frequency spectrum of the original input signal and the frequency response of the system.
check this link for more info.
TeE ThE EdE
