What do you mean by that ?
And about transformer : because we have dphi/dt , thus it can't be saturated simply , however at SMPS systems at transformers we have to create gap on it's core , because the square wave , would be enough , to saturate the core !
Best Wishes
Goldsmith
Thank you for your reply
I mean that air gap store energy or there is no energy store in the core.
Simply I always to add air gap to inductors that i design but for transformer i do not add air gap and someone ask me why i do that i forget why i do that!
Air gap can't store energy ! it will decrease the permeability and it will add : Rg+Rcore ( rg added ) . to prevent from nonlinearity .
And at some of transformers we have to use air gap , but if you're referring to the usual transformers , as i mentioned at past because the polarity will change we won't have any specific problem ( don't forget if your waveform is square wave , all things will change )
for SMPS at h bridge , because the polarity will change , ( polarity of transformer ) . there will be , lower problems , but because the square wave , at an obvious time can be considered as a DC signal , and you'd better to create gap space in core , thus you can achieve higher powers .
