Why voltage drops between drain and source of Mosfet
nihan_A
Newbie level 5
Hello!
I have a problem with driving P channel mosfet.
I am trying to control power voltage of a TFT. As you can see below when TFT_Power_EN signal is low I expect there would be 3.3V at the Drain of the mosfet which is labeled as TFT Power. But when I check the signal it is just 2.5V
I understand, since mosfet has its own resistance there would be some loss. But when I check mosfet datasheet 0.8V loss is too much.
I thought maybe TFT wants to draw more current so it result voltage drop so I connect one more mosfet as parallel but no change.
If anyone have experience or any idea please help me.
P.s. Measured current from the drain is 460ma with 2.5V drain voltage
Considering transistor heating, the voltage drop is still in the expectable range. You need a transistor with lower Rds,on and higher current rating for this application.
Sim and part specs look OK.
What is your gate drive level ? This is the backlight of the TFT, right ? Which I used a
6 ohm as drain load, but should be a diode drop of LEDs in backlight ? Or does this
supply a DC/DC in TFT that in turn drives B/L ?
If Vgs is - 3.3 the typical curves show ~ .5 ohms Rdson, which should be OK. But you
should look at worst case. Worst case at Vgs of -2.5 is ~ 1.5 ohms
Regards, Dana.
Your simulation doesn't reflect junction overtemperature due to power dissipation.
Power in device quite low, roughly ~ 100 mW, not really a consideration. Top curve.
Regards, Dana.
The sim shows Vds << .8 V, thats why the power curve shows the ~ 100 mW.
To your point sim is only run at 25 C.
The Id vs T shows a less than doubling 25C to 150C, ambient.
But above curves typ and at Vgs -4.5.
If I look at a "typ" Rdson vs T -
We see it is impacting circuit Pdiss via rise in it.
I would have to use a different sim to get at the DC situation in a more complete fashion,
non withstanding accuracy of spice model issues.
Regards, Dana.
Always read the data sheet carefuly for worst case Vgs, Rds-on and power dissipation for minimum footprint .....!
Reactions: FvM
...when TFT_Power_EN signal is low I expect there would be 3.3V at the Drain of the mosfet which is labeled as TFT Power. But when I check the signal it is just 2.5V
Stupid question, sorry to ask:
What do you mean in volts when you say "...when TFT_Power_EN signal is low..."? When it's at 0V and turning the PMOS on?
Thank you all for replying.
Regards, Dana.
Yes it is just DC supply. My gate drive level is 0V for case mosfet on and 3.3V for off.
I want to inform you all Mosfet is not really heating much while TFT draws 460mA. It is lower than 40 C. And I tried to divide current by adding one more mosfet as parallel but it made no change.
Yes, it is 0V so mosfet should turn on.
    d123
If your voltage and current measurements are real, the calculated power and delta T numbers are correct as well. The value is for junction temperature, case temperature may be considerably lower.
An optimistic assumption would be that the transistor voltage drop and power dissipation are actually lower and the voltage is dropped somewhere else...
You can't parallel MOSFETS without using ballasting or active current
circuitry. The variation from one MOSFET to another can produce one part
taking most of the current, the others paralleled not so much.
Regards, Dana.
I agree that paralleling BJTs is problematic without balancing.
But paralleling MOSFETs is not that problematic. For sure the wiring/PCB layout should care for about identical source serial resistances.
Klaus
In this part the Vth variance device to device is > 2:1.
In linear region
In sat region
Only if Vgs >> Vth is Vth variance of lesser concern. In case of logic level MOSFETs
Usable Vgs range in most designs leave Vth with significant effect.
There is a very strong dependence on basic device parameters of Idrain, so I
register disagreement on paralleling unless precautions are taken.
Regards, Dana.
