T
treez
We have had some of our 3Kw offline battery chargers failing so we opened them up and looked inside. Battery voltage is 250-400VDC
We notice a half bridge LLC converter running after an interleaved PFC stage.
The LLC secondary diodes are ISL9R1560P2. these have 29ns reverse recovery time but a higher forward voltage than many diodes.
ISL9R1560P2 UF diode datasheet:
https://www.fairchildsemi.com/datasheets/IS/ISL9R1560P2.pdf
Why have they not used output diodes with greater reverse recovery time, that have significantly lower forward voltage?
..eg they could have used VS-15ETL06
VS-15ETL06 UF diode datasheet:
So, in an LLC converter, which has very minimal reverse recovery of the output diodes, why have they opted for a super fast diode with higher forward voltage, rather than a slightly slower diode, with a much lower forward voltage?
(there are no synchronous FETs used)
