internetuser2k12
Banned
Hello!
Why this code is not displaying "Cytron Tech" on LCD. The same code if compiled on another system is displaying on LCD, but if compiled on my system the LCD is blank.
It is a Hi Tech C Code. The kabian4.hex displays data on LCD but uart1.hex doesn't display anything on LCD. Kabian4.hex uses the same code but compiled on a different machine. can somebody compile the code for 20 MHz and post the hex file?
// ===== SMART GROUP ======
// ===== LIM KIA YING T18157 =====
// LCD display with the motor
// LCD display is to show the direction of the motor
// PORT B and PORT C is for motor
// PORT D is for LCD display
#include <pic.h>
#include <string.h>
#include <htc.h>
__CONFIG(0x3f32); //3FFB
#define _XTAL_FREQ 20000000
//=========== define of the motor ports ============
#define L293D_E RA0 //Enable of L293D
#define L293D_A RB1 //Positive of motor
#define L293D_B RA2 //Negative of motor
#define L293D_C RA3 //Positive of motor
#define L293D_D RB2 //Negative of motor
#define L293D_G RA5 //Positive of motor
#define L293D_H RE0 //Negative of motor
#define L293D_J RE1 //Positive of motor
#define L293D_K RE2 //Negative of motor
//=========== define the LCD ports =================
#define rs RB7 //RS pin of the LCD display
#define e RB6 //E pin of the LCD display
#define lcd_data PORTD //LCD 8-bit data PORT
//=========== define LED Signal Light =============
#define signal_left RB5 //Left side LED
#define signal_right RB4 //Right side LED
//=========== define Buzzer ================
#define buzzer RB3 //Buzzer
//=========== define switch ===============
#define switch1 RC0 //Switch 1 for LENG KABIAN
#define switch2 RC1 //Switch 2 for LENG KABIAN
#define switch3 RC2 //Switch 3 for LENG KABIAN
#define switch4 RC3 //Switch 4 for LENG KABIAN
#define switch5 RC4 //Switch 5 for LENG KABIAN
#define switch6 RC5 //Switch 6 for LENG KABIAN
#define switch7 RC6 //Switch 7 for LENG KABIAN
#define switch8 RC7 //Switch 8 for LENG KABIAN
//========== Motor Function Prototypes ===================
void rotate_forward_LCD_1(void); //Forward run function
void rotate_backward_LCD_1(void); //Backward run function
void rotate_leftside_LCD_1(void); //Leftside run function
void rotate_rightside_LCD_1(void); //Rightside run function
void rotate_forward_LCD_2(void); //Forward run function
void rotate_backward_LCD_2(void); //Backward run function
void rotate_leftside_LCD_2(void); //Leftside run function
void rotate_rightside_LCD_2(void); //Rightside run function
void breaks_1(void); //Motor stop function
void breaks_2(void); //Motor stop function
void breaks_3(void); //Motor stop function
void breaks_4(void); //Motor stop function
void delay_motor(void); //Some delay (Motor)
void delay_led(void); //Some delay (LED)
void delay_buzzer(void); //Some delay (Buzzer)
void command_error(void); //Command error
//======== LCD Function Prototypes =========
void delay_lcd(unsigned long data);
void send_config(unsigned char data);
void send_char(unsigned char data);
void lcd_goto(unsigned char data);
void lcd_clr(void);
void send_string(const char *s);
// ======= UART Function Prototypes =======
void uart_send(unsigned char data);
unsigned char UART_Receive_Char(void); //receive uart value
unsigned char UART_Receive_String(void);
void uart_str(const char *s);
//======= LED Signal LED ==========
void led_off_l(void);
void led_off_r(void);
void led_signal_left(void);
void led_signal_right(void);
void led_signal_sos(void);
void led_sos_off(void);
//========== Buzzer Function Prototypes ======
void buzzer_stop(void);
// ========== Program Start ==============
unsigned int count = 0, count1 = 0, uart_receive_flag, cmp_;
unsigned char myString[4] = "XX", myString2[4];
void interrupt ISR(void)
if(RCIF) //If UART Rx Interrupt
if(OERR) //if over run error, then reset the receiver
CREN = 0;
CREN = 1;
myString[count] = RCREG;
myString2[count1] = RCREG;
count++;
count1++;
if(count == 2) count = 0;
if(count1 == 3) count1 = 0;
RCIF = 0;
// =========== MOTOR CODING ============
void rotate_forward_LCD_1(){
L293D_A = 1; //Make positive of motor 1
L293D_B = 0; //Make negative of motor 0
L293D_E = 1; //Enable L293D
unsigned long delay_time=5000;
//setup ADC
//ADCON1 = 0b00000110; //set ADx pin digital I/O
//configure lcd
send_config(0b00000001); //clear display at lcd
send_config(0b00000010); //lcd return to home
send_config(0b00000110); //entry mode-cursor increase 1
send_config(0b00001100); //display on, cursor off and cursor blink off
send_config(0b00111000); //function set
//display startup message
lcd_clr(); //clear lcd
lcd_goto(5); //set the lcd cursor to location 0
send_string("PSM.L"); //display "Cytron Tech."
lcd_goto(27); //set the lcd cursor to location 20
send_string("UP"); //display "SK40C"
void rotate_backward_LCD_1(){
L293D_A = 0; //Make positive of motor 0
L293D_B = 1; //Make negative of motor 1
//setup ADC
//configure lcd
lcd_goto(25); //set the lcd cursor to location 20
send_string("DOWN"); //display "SK40C"
void rotate_leftside_LCD_1(){
L293D_C = 1; //Make positive of motor 1
L293D_D = 0; //Make negative of motor 0
//setup ADC
//configure lcd
send_string("LEFT"); //display "SK40C"
void rotate_rightside_LCD_1(){
L293D_C = 0; //Make positive of motor 0
L293D_D = 1; //Make negative of motor 1
//setup ADC
//configure lcd
send_string("RIGHT"); //display "SK40C"
void rotate_forward_LCD_2(){
L293D_G = 1; //Make positive of motor 1
L293D_H = 0; //Make negative of motor 0
//setup ADC
//configure lcd
send_string("PSM.R"); //display "Cytron Tech."
void rotate_backward_LCD_2(){
L293D_G = 0; //Make positive of motor 0
L293D_H = 1; //Make negative of motor 1
//setup ADC
//configure lcd
void rotate_leftside_LCD_2(){
L293D_J = 1; //Make positive of motor 1
L293D_K = 0; //Make negative of motor 0
//setup ADC
//configure lcd
void rotate_rightside_LCD_2(){
L293D_J = 0; //Make positive of motor 0
L293D_K = 1; //Make negative of motor 1
//setup ADC
//configure lcd
void command_error(){
buzzer=1;
//setup ADC
//configure lcd
send_string("COMMAND"); //display "Cytron Tech."
send_string("ERROR"); //display "SK40C"
void breaks_1(){
L293D_E = 0; //Disable L293D
void breaks_2(){
void breaks_3(){
void breaks_4(){
void buzzer_stop(){
buzzer=0;
// ======== LED Signal Light ==========
void led_signal_left()
signal_left=1;
//setup ADC
//configure lcd
send_string("SIGNAL"); //display "Cytron Tech."
void led_signal_right()
signal_right=1;
//setup ADC
//configure lcd
void led_signal_sos()
signal_right=1;
signal_left=1;
//setup ADC
//configure lcd
lcd_goto(3); //set the lcd cursor to location 0
send_string("EMERGENCY"); //display "Cytron Tech."
lcd_goto(23); //set the lcd cursor to location 20
send_string("EMERGENCY"); //display "SK40C"
void led_off_l()
signal_left=0;
void led_off_r()
signal_right=0;
void led_sos_off()
signal_left=0;
signal_right=0;
// ========= TIME DELAY ============
void delay_motor(){ //delay for motor
unsigned char i,j,k;
for(i=0;i<0x20;i++)
for(j=0;j<100;j++)
for(k=0;k<100;k++);
void delay_led(){
for(i=0;i<0x20;i++)
for(j=0;j<255;j++)
for(k=0;k<255;k++);
void delay_buzzer(){
for(i=0;i<0x20;i++)
for(j=0;j<150;j++)
for(k=0;k<150;k++);
void main(){ //Our main function
TRISA=0x00; //One side of Motor
TRISB=0x00; //LCD and Buzzer
TRISD=0x00; //LCD display
TRISE=0x00; //One side of Motor
PORTA=0; //Switch
PORTB=0;
PORTD=0;
PORTE=0;
TRISC=0xFF; //Switch
PORTC=0; //Switch
ADCON1 = 0b10000111;
CMCON = 0b00000111;
CVROE = 0;
//Configure UART
SPBRG=129; //set baud rate as 9600 baud
BRGH=1; //baud rate high speed option
TXEN=0; //disable transmission
TX9 =0; //8-bit transmission
RX9 =0; //8-bit reception
CREN=1; //enable reception
SPEN=1; //enable serial port
SYNC = 0;
SPEN = 1;
RX9 = 0;
CREN = 1;
FERR = 0;
OERR = 0;
TXIE = 0;
RCIE = 1;
//Include these settings
GIE = 1; //Enable global interrupts
PEIE = 1; //Enable Peripheral Interrupts
count = 0;
lcd_goto(2); //set the lcd cursor to location 0
send_string("Cytron Tech");
while(1) { //Do this infinitely
if((myString[0] == 'L') && (myString[1] == 'U'))
//PORTBbits.RB4 = 1;
rotate_forward_LCD_1(); //Run forward
delay_motor(); //Some delay
breaks_1(); //Stop
else if((myString[0] == 'L') && (myString[1] == 'D')) //if data received, turn left mirror down
rotate_backward_LCD_1(); //Run Backwards
breaks_1(); //Stop
else if((myString[0] == 'L') && (myString[1] == 'L')) //if data received, turn left mirror left
rotate_leftside_LCD_1(); //Run left
breaks_2(); //Stop
else if((myString[0] == 'L') && (myString[1] == 'R')) //if data received, turn left mirror right
rotate_rightside_LCD_1(); //Run right
breaks_2(); //Stop
else if((myString[0] == 'R') && (myString[1] == 'U')) //if data received, turn right mirror up
rotate_forward_LCD_2(); //Run forward
breaks_3(); //Stop
else if((myString[0] == 'R') && (myString[1] == 'D')) //if data received, turn right mirror down
rotate_backward_LCD_2(); //Run Backwards
breaks_3(); //Stop
else if ((myString[0] == 'R') && (myString[1] == 'L')) //if data received, turn right mirror left
rotate_leftside_LCD_2(); //Run left
breaks_4(); //Stop
else if((myString[0] == 'R') && (myString[1] == 'R')) //if data received, turn right mirror right
rotate_rightside_LCD_2(); //Run right
breaks_4(); //Stop
else if ((myString[0] == 'L') && (myString[1] == 'S')) //if data received, left signal is lighted up
led_signal_left(); //LED Signal light turn left
delay_led(); //Some delay
led_off_l(); //LED Signal light off
else if((myString[0] == 'R') && (myString[1] == 'S')) //if data received, right signal is lighted up
led_signal_right(); //LED Signal light turn right
led_off_r(); //LED Signal light off
else if((myString2[0] == 'S') && (myString2[1] == 'O') && (myString2[2] == 'S')) //if data received, emergency signal light will be lighted up
led_signal_sos(); //Emergency light on
led_sos_off(); //Emergency light off
//else if ((myString[0] != 'L') || (myString[0] != 'R') || (myString2[0] != 'S')
//|| (myString[1] != 'R') || (myString[1] != 'L') || (myString[1] != 'U')
//|| (myString[1] != 'D') || (myString2[1] != 'O') || (myString2[2] != 'S')
//|| (myString[0] != 'X') || (myString[1] != 'X'))
else if ((myString[0] != 'L') && (myString[1] != 'U') ||
(myString[0] != 'L') && (myString[1] != 'D') ||
(myString[0] != 'L') && (myString[1] != 'R') ||
(myString[0] != 'L') && (myString[1] != 'L') ||
(myString[0] != 'R') && (myString[1] != 'U') ||
(myString[0] != 'R') && (myString[1] != 'D') ||
(myString[0] != 'R') && (myString[1] != 'R') ||
(myString[0] != 'R') && (myString[1] != 'L') ||
(myString[0] != 'L') && (myString[1] != 'S') ||
(myString[0] != 'R') && (myString[1] != 'S') ||
(myString[0] != 'X') && (myString[1] != 'X') ||
(myString2[0] != 'S') && (myString2[1] != 'O') && (myString2[2] != 'S'))
command_error(); //Command error
delay_buzzer(); //Some delay
buzzer_stop(); //
else if((myString[0] == 'X') && (myString[1] == 'X'))
else {
// ========== LCD CODING ========
void delay_lcd(unsigned long data) //delay function, the delay time
{ //depend on the given value
for( ;data>0;data--);
void send_config(unsigned char data) //send lcd configuration
rs=0; //set lcd to configuration mode
lcd_data=data; //lcd data port = data
e=1; //pulse e to confirm the data
delay_lcd(50);
e=0;
delay_lcd(50);
void send_char(unsigned char data) //send lcd character
rs=1; //set lcd to display mode
delay_lcd(10);
e=0;
delay_lcd(10);
void lcd_goto(unsigned char data) //set the location of the lcd cursor
{ //if the given value is (0-15) the
if(data<16) //cursor will be at the upper line
{ //if the given value is (20-35) the
send_config(0x80+data); //cursor will be at the lower line
} //location of the lcd cursor(2X16):
else // -----------------------------------------------------
{ // | |00|01|02|03|04|05|06|07|08|09|10|11|12|13|14|15| |
data=data-20; // | |20|21|22|23|24|25|26|27|28|29|30|31|32|33|34|35| |
send_config(0xc0+data); // -----------------------------------------------------
void lcd_clr(void) //clear the lcd
send_config(0x01);
delay_lcd(600);
void send_string(const char *s) //send a string to display in the lcd
while (s && *s)send_char (*s++);
