Nov 30, 2007 #1 F firsttimedesigning Full Member level 1 Joined Jul 4, 2007 Messages 97 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,288 Activity points 2,241 why is the open loop gain of an opamp can be expressed as the following equation: Aol = Aol(0) / (1+j (f/f3db)) where, Aol = open loop gain Aol(0) = open loop gain of the opamp when the frequency is 0 f = frequency f3db = 3db cutoff frequency
Nov 30, 2007 #2 hr_rezaee Advanced Member level 3 Joined Oct 6, 2004 Messages 747 Helped 109 Reputation 218 Reaction score 24 Trophy points 1,298 Location Iran-Mashhad Activity points 4,025 Open Loop Gain Hi this is just one pole model. why not? for f<<f3db |Aol|=Aol(0) for f=f3db |Aol|=Aol(0)/√(2) for f=∞ |Aol|=0 why not? it is the simplest model. yes, you can use more complicated models depend your circuit and precision.
Dec 2, 2007 #3 P phosphor_zhu Junior Member level 1 Joined Oct 29, 2007 Messages 19 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Activity points 1,393 Re: Open Loop Gain you may use small signal model to get the expresion of gain; and then you make sure the main pole of ur circuit. then , i think u get that.
Dec 2, 2007 #4 P peterwang Member level 1 Joined Oct 31, 2007 Messages 33 Helped 5 Reputation 10 Reaction score 2 Trophy points 1,288 Activity points 1,436 Re: Open Loop Gain I suggest you read Ch7 of : Op Amps for Everyone (pdf file) Author: Ron Manchini You can get it here: **broken link removed**
Dec 3, 2007 #5 Q qutang Full Member level 5 Joined Oct 25, 2004 Messages 305 Helped 9 Reputation 18 Reaction score 3 Trophy points 1,298 Activity points 1,581 Open Loop Gain this is a frequency dominant equation.
Dec 3, 2007 #6 S satyasiva Full Member level 1 Joined Nov 9, 2006 Messages 98 Helped 5 Reputation 10 Reaction score 2 Trophy points 1,288 Activity points 1,714 Open Loop Gain because the gain depends onfrequency
