EDA_hg81
Advanced Member level 2
In the design, two PCB are connected by a 50 pins flat flex connector, which provides Grounds and Control signals from master board to slave board.
We have two shipment PCB with the same design. Right now the problem is the Ground of control signal of the second shipment PCB has a 0.5V voltage level shift from real Ground which is hard for slave board to recognize the signals correctly.
Only difference between the first PCB and second PCB is the flat flex connector.
Do you think flat flex connector is the reason make the Ground of control signal shifted 0.5V higher ?
Thanks.
Thanks.
