internetuser2k12
Banned
Hello! I want to know why serial transmit is not working?
#include<reg51.h>
#include<string.h>
//Function declarations
void cct_init(void);
void delay(int);
void lcdinit(void);
void writecmd(int);
void writedata(char);
void ReturnHome(void);
void display();
void display2();
void send_uart(void);
void send_string_uart(unsigned char string[]);
//Pin description
P2.4 to P2.7 is data bus
P1.0 is RS
P1.1 is E
// Defines Pins
sbit RS = P1^0;
sbit E = P1^1;
unsigned char card_id[12];
unsigned char tag[12] = { 49, 50, 51, 52, 53, 54, 55, 56, 57, 49, 50, 51 };
unsigned char read_id[12];
unsigned char current_byte = 0;
unsigned int display_flag = 0;
unsigned int key = 0;
unsigned int count = 0;
unsigned char mystring[] = "AT89C51";
void recieve() interrupt 4 //Function to recieve data serialy from RS232
card_id[current_byte]=SBUF;
RI=0; // Reset the serial interrupt after recieving the byte
current_byte++;
// Main program
void main(void)
cct_init(); //Make all ports zero
TMOD=0x20; //Enable Timer 1
TH1=0XFD;
SCON=0x50;
TR1=1;
EA=1;
ES=1;
lcdinit(); //Initilize LCD
writedata('U'); //write
writedata('n'); //write
writedata('i'); //write
writedata('q'); //write
writedata('u'); //write
writedata('e'); //write
writedata(' '); //write
writedata('C'); //write
writedata('a'); //write
writedata('r'); //write
writedata('d'); //write
writedata('I'); //write
writedata('d');
ReturnHome(); //Return to 0 position
while(1)
while(current_byte!=12);
display();
delay(500000);
key=0;
for(count=0;count<12;count++)
if(card_id[count]==tag[count])
key++;
count = 0;
if((key == 12) && (display_flag == 0)) {
delay(500000);
display2();
display_flag = 1;
key = 0;
send_uart();
send_string_uart(mystring);
if((tag == card_id) && (display_flag == 0)) {
display2();
display_flag = 1;
void send_uart(void) {
TI = 0;
SBUF = 'A';
while(TI == 0);
delay(500000);
void send_string_uart(unsigned char string[]) {
unsigned int count;
for(count = 0; count < strlen(string); count++) {
TI = 0;
SBUF = string[count];
while(TI == 0);
delay(500000);
void display() // Function to display the unique id
unsigned char count;
writecmd(0xC1); //Place cursor to second position of second line
writedata(card_id[count]);
//read_id[count] = card_id[count] + 48;
current_byte=0;
void display2() // Function to display the unique id
//unsigned char count;
//for(count=0;count<12;count++)
//writedata(tag[count]);
writedata('A'); //write
writedata('c'); //write
writedata('p'); //write
writedata('t'); //write
void cct_init(void)
P0 = 0x00; //not used
P1 = 0x00; //not used
P2 = 0x00; //used as data port
P3 = 0x00; //used for generating E and RS
void delay(int a)
int i;
for(i=0;i<a;i++); //null statement
void writedata(char t)
RS = 1; // This is data
P2 &= 0x0F; // Make P2.4 to P2.7 zero
P2 |= (t&0xF0); // Write Upper nibble of data
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
P2 |= ((t<<4)&0xF0);// Write Lower nibble of data
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
void writecmd(int z)
RS = 0; // This is command
P2 |= (z&0xF0); // Write Upper nibble of data
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
P2 |= ((z<<4)&0xF0);// Write Lower nibble of data
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
void lcdinit(void)
///////////// Reset process from datasheet /////////
delay(15000);
P2 |= (0x30&0xF0); // Write 0x3
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(4500);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(300);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(650);
P2 |= (0x20&0xF0); // Write 0x2
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(650);
writecmd(0x28); //function set
writecmd(0x0c); //display on,cursor off,blink off
writecmd(0x01); //clear display
writecmd(0x06); //entry mode, set increment
void ReturnHome(void) //Return to 0 location
writecmd(0x02);
delay(1500);
