fahim1
Member level 4
hi heres my code and the value o fignal is calculated correctly but at the ninth clk when the calculation finished ,out put should get the value but it didnt happen?
how could i fix it??
tnx
tnx
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_unsigned.all;
USE ieee.std_logic_arith.all;
entity serialnew is
port(a,b : in std_logic_vector(3 downto 0); ---b delete
clk : in std_logic;
out3 : out std_logic_vector(7 downto 0));
end serialnew;
architecture serialnew_arch of serialnew is
signal count :integer range 0 to 9 := 0 ;
signal c0,c1,c2,c3 : std_logic := '0' ;
BEGIN
process(clk)
variable sum0,sum1,sum2,sum3 : std_logic := '0';
variable temp0,temp1,temp2,temp3 : std_logic_vector(1 downto 0) :="00";
variable outtemp : std_logic_vector(7 downto 0) := "00000000"; --?/
variable inp :std_logic_vector(3 downto 0) := "0000";
begin
if (clk='1' and clk'event) then
if (count <9) then
case count is
when 1 => inp := b(0) & "000";
when 2 => inp := b(1 downto 0)&"00";
when 3 => inp := b(2 downto 0)& "0" ;
when 4 => inp := b(3 downto 0);
when 5 => inp := '0'&b(3 downto 1);
when 6 => inp := "00"&b(3 downto 2);
when 7 => inp := "000"&b(3);
when others => inp := "0000";
end case;
temp0(0) := ( a(0) and inp(3) )xor c0 ;
temp0(1) := ( a(0) and inp(3) )and c0 ;
sum0 := temp0(0);
c0 <= temp0(1);
temp1(0) := (a(1) and inp(2))xor c1 xor sum0;
temp1(1) := ((a(1) and inp(2))and sum0) or (sum0 and c1 ) or ((a(1) and inp(2)) and c1) ;
sum1 := temp1(0);
c1 <= temp1(1);
temp2(0) := (a(2) and inp(1))xor c2 xor sum1 ;
temp2(1) := ((a(2) and inp(1))and sum1) or (sum1 and c2) or ((a(2) and inp(1)) and c2) ;
sum2 := temp2(0);
c2 <= temp2(1);
temp3(0) := (a(3) and inp(0))xor c3 xor sum2 ;
temp3(1) := ((a(3) and inp(0))and sum2) or (sum1 and c2) or ((a(3) and inp(0))and c3) ;
sum3 := temp3(0);
c3 <= temp3(1);
outtemp(count ) := sum3;
count <= count +1 ;
elsif (count = 9 ) then
out3 <= '0' & outtemp(7 downto 1);
elsif (count = 10 ) then
end if;
end if;
end process;
end serialnew_arch;
