Why offset voltage of mos transistor is smaller than bipolar
hr_rezaee
Advanced Member level 3
Iran-Mashhad
hi
Why offset voltage of mos transistors is smaller than offset voltage of bipolar transistors?
please, answer and if you can introduce references.
regards
Re: Why offset voltage of mos transistor is smaller than bip
hr_rezaee said:
hi
regards
You can calculate, but shortly bipolars have exponential, and mos ()^2 characteristics (lower gm). This means that same ΔI mismatch of differential pair (for example caused by resistor mismatch) would produce smalled input voltage mismatch in the case of bipolars...
    hr_rezaee
The mismatch is depends on the circuit design and process matching. But not depends on MOS or bipolar.
Btw, ususally bipolar transistor have lower Vbe matching than MOS Vt
hi
thanks
it is logical.
regards
But some text book says bip has little offset voltage ?
hi
it is true.
reards
bipolar are ALWAYS better matched than mosfet. probably 10x better (1mV vs 10mV) with careful layout. it's due to the fact that junction diffusions are easier to control than oxide characteristics.
