hspice not generating .sw
I installed hspice_2005_03 in redhat9.0 .The hspice can run. But it can not generate the files,such as *.sw*,*.tr*,*.ac*. So i can not observe the waves with cscope.
there is the *.lis file:
Using: /home/cs/synopsys/hspice/linux/hspice
Incorrectly built binary which accesses errno, h_errno or _res directly. Needs to be fixed.
****** HSPICE W-2005.03 (20050128) 16:55:52 11/16/2006 linux
Copyright (C) 2005 Synopsys, Inc. All Rights Reserved.
Unpublished-rights reserved under US copyright laws.
This program is protected by law and is subject to the
terms and conditions of the license agreement found in:
/home/cs/synopsys/hspice/license.txt
Use of this program is your acceptance to be bound by this
license agreement. HSPICE is the trademark of Synopsys, Inc.
Input File: /home/cs/hspice_ex/ss.sp
lic:
lic: FLEXlm: v8.4b
lic: USER: cs HOSTNAME: localhost.localdomain
lic: HOSTID: 00e04c80bf1d PID: 4250
lic: Using FLEXlm license file:
lic: /home/cs/synopsys/license.dat
lic: Checkout hspice; Encryption code: DCFE951F005EC01439B7
lic: Notice: NOT TO BE SOLD
lic: License/Maintenance for hspice will expire on 31-dec-2050/2005.3
lic: NODE LOCKED DEMO license on host 00e04c80bf1d
lic:
Init: read install configuration file: /home/cs/synopsys/hspice/meta.cfg
Init: hspice initialization file: /home/cs/synopsys/hspice/hspice.ini
* reading file: /home/cs/synopsys/hspice/hspice.ini
.include 'ex1.sp'
*this is a gui generated header file. it is overwritten and updated for each run.
.include 'diode.sp'
* circuit description
vd 1 0 dc 700mv ac 1
d1 1 2 diode
r1 2 0 1k
* diode model statement
.model diode d
* analysis requests*
.dc vd 0v 800mv 200uv
.temp 0 27 100
* output requests
.probe dc i(d1) v(2)
.end
1 ****** HSPICE W-2005.03 (20050128) 16:55:52 11/16/2006 linux
****** diode model parameters tnom= 25.000 temp= 25.000
*** common model parameters model name: 0:diode ****
names values units names values units names values units
1*** dc breakdown parameters ***
vb= 0. volts ibv= 1.00m amps
2*** parasitic resistance parameters ***
rs= 0. ohms
3*** capacitance parameters ***
fc= 500.00m fcs= 500.00m m= 500.00m
mjsw= 330.00m pb= 800.00m volts php= 800.00m volts
tt= 0. secs cjo= 0. f/area cjp= 0. f/pj
4*** temperature effect parameters ***
tlev= 0. tlevc= 0. tcv= 0. v/deg k
trs= 0. /deg cta= 0. /deg ctp= 0. /deg
xti= 3.00 xtitun= 3.00 eg= 1.11 ev
gap1= 702.00u ev/deg gap2= 1.11k deg ttt1= 0. /deg
ttt2= 0. /deg2 tm1= 0. /deg tm2= 0. /deg2
tpb= 0. v/deg k tphp= 0. v/deg k tref= 25.00 deg c
5*** noise parameters ***
kf= 0. af= 1.00
*** level 1 model parameters ***
level= 1.00 is= 10.00f amps jsw= 0. amps
n= 1.00 nbv= 1.00 ik= 0. amp
area= 1.00 pj= 0. ikr= 0. amp
expli= 0. amps explir= 0. amps jtun= 0. amps
jtunsw= 0. amps ntun= 30.00
***** job concluded
****** job statistics summary tnom= 25.000 temp= 100.000
total memory used 185 kbytes
# nodes = 4 # elements= 4
# diodes= 1 # bjts = 0 # jfets = 0 # mosfets = 0 # va device = 0
analysis time # points tot. iter conv.iter
op point 0.00 1 0
dc sweep 0.20 4001 24030
readin 0.01
errchk 0.00
setup 0.00
output 0.00
total cpu time 0.21 seconds
job started at 16:55:52 11/16/2006
job ended at 16:55:52 11/16/2006
lic: Release hspice token(s)
>info: ***** hspice job concluded
HSPICE job /home/cs/hspice_ex/ss.sp completed.
???? 11???? 16 16:55:52 CST 2006
Please help me!!!
thanks!!!
