Why MPEG2 MP@LL and MPEG1 have different bit rates?
davyzhu
Advanced Member level 1
oriental
MPEG2 MP@LL and MPEG1?
Hi all,
I heard that MPEG2 and MPEG1 use same compression methods.
MPEG2's MP@LL and MPEG1 are all 4:2:0, 352*288*30. But MPEG2's MP@LL is 4Mbit/s and MPEG1 is 1.5Mbit/s. Why they have different bit rates?
And if I want to do 352*288*30 video compression. Shall I choose MPEG2 or MPEG1??
Any suggestions will be appreciated!
Best regards,
Davy
Re: MPEG2 MP@LL and MPEG1?
Dear davyzhu,
MEPG-1 is the standard for VCDs and MPEG-2 is standard for DVDs......
They both use the same tools but MPEG-2 has few advance tools like Interlaced Videos......... Otherwise no major difference...........
Actually the target bitrate of MPEG-1 was for VCDs only hence it is a constant bit rate standard too.............. while MPEG-2 has a facility for Variable Bit rate and its peak bit rate is 10 Mbps and minimium it can go below 1Mbps too
If you want to do compression of CIF [352*288*30] then u can use both standards but it also depends upon what is ur target application..... MPEG-1 and MPEG-2 are both for multimedia. But i thin MPEG-2 is mostly done on FULL-D1 and for CIF it is prefered to use MPEG-1 but again i think it will be a constant bit rate...
Best Regards,
    davyzhu
