Why is this PWM not working? (mikroC code)
Why this pwm is not working? Nothing appears on the oscilloscope.
mikroC Code
#define SW PORTA.F0
void main() {
     int speed_counter;
     TRISA = 0xFF;
     TRISC = 0x00;
     PORTA = 0x00;
     PORTC = 0x00;
     PWM1_Init(33000);
     PWM1_Start();
     speed_counter = 0;
     while(1) {
          if(SW == 1) {
                Delay_ms(20);
                if(SW == 1) {
                   speed_counter = speed_counter + 1;
          if(speed_counter > 4) {
               speed_counter = 0;
          switch (speed_counter) {
                 case 0: {
                      PWM1_Set_Duty(0);
                      break;
                 case 1: {
                      PWM1_Set_Duty(64);
                      break;
                 case 2: {
                      PWM1_Set_Duty(127);
                      break;
                 case 3: {
                      PWM1_Set_Duty(192);
                      break;
                 case 4: {
                      PWM1_Set_Duty(255);
                      break;
                 default:
  • PIC16F877_PWM.rar
re: Why this is not working?
mikroC Code
#define SW PORTA.F0
void main() {
     int speed_counter;
     TRISA = 0xFF;
     TRISC = 0x00;
     PORTA = 0x00;
     PORTC = 0x00;
     PWM1_Init(33000);
     PWM1_Start();
     speed_counter = 0;
     while(1) {
          if(SW == 1) {
                Delay_ms(20);
                if(SW == 1) {
               speed_counter = 0;
                 case 0: {
                      PWM1_Set_Duty(0);
                      break;
                 case 1: {
                      PWM1_Set_Duty(64);
                      break;
                 case 2: {
                      PWM1_Set_Duty(127);
                      break;
                 case 3: {
                      PWM1_Set_Duty(192);
                      break;
                 case 4: {
                      PWM1_Set_Duty(255);
                      break;
                 default:
Could you please provide the rest of the pertinent source code so that I can see your initialization functions. While the code above looks fine from what I could tell, there might be something that is not being initialized correctly.
Also, would it be possible for you to provide a .pdf of your schematic. Unfortunately I do not have a copy of OrCAD installed on my machine.
Regards,
Willis
There is no Initialization. I have posted the full code. All PWM things are done by the PWM library functions. That is a proteus .dsn file.
  • pic16f877_pwm.PDF
you must delete the last flower bracket. which is extra. and you must power on the microcontroller, thus, attach a logic state to the pin^1(Vpp) of pic microcontroller. and make it logic high.
#define SW PORTA.F0
void main() {
     int speed_counter;
     TRISA = 0xFF;
     TRISC = 0x00;
     PORTA = 0x00;
     PORTC = 0x00;
     PWM1_Init(33000);
     PWM1_Start();
     speed_counter = 0;
     while(1)
          if(SW == 1)
                   Delay_ms(20);
               speed_counter = 0;
                 case 0: {
                      PWM1_Set_Duty(0);
                      break;
                 case 1: {
                      PWM1_Set_Duty(64);
                      break;
                 case 2: {
                      PWM1_Set_Duty(127);
                      break;
                 case 3: {
                      PWM1_Set_Duty(192);
                      break;
                 case 4: {
                      PWM1_Set_Duty(255);
                      break;
                 default:
Yes. I did that too, but I don't get the pulses.
ok, what is your aim to do with that?
be specific in your question. what percentage of pulses do you need exactly?
Re: Why this is not working???????
I need 25%, 50% and 75% PWM Pulses. It is used to control the speed of motor. But in simulation the motor is running on its own without button being pressed.
I did the same circuit with PIC16F887 and it is working fine.
  • PIC16F887_PWM.rar
Hi friend
Check alternative function over Port A pin which is you had to use as a input.
There is one possibility, that you initialize speed_counter = 0; and if your input pin not working, your switch-case logic select case 0 where PWM duty cycle is 0. So you don't get any outpur.
So check your input port pin as well as for testing purpose initialize speed_counter = 1 or 2 or 3;
Best of luck.
OK. Thanks It is working fine. The problem was with the switch.
  • PIC16F877_PWM.rar
