why is this for loop not synthesizable
verilog2vhdl
Newbie level 6
Newbie level 6
for loop is synthesizable
for i in I_b'RANGE downto 0 LOOP
O_g_tmp(i - 1) <= I_b(i) XOR I_b(i - 1);
END LOOP;
I see the error as
Illegal use of 'range/'reverse_range attribute
is I_n(-1) defined?
or should you only go downto 1?
The code has been modified as follows and still see the same
for i in I_b'RANGE downto 1 LOOP
END LOOP;
I see the error as
for i in I_b'RANGE LOOP
end loop;
If u want range attribute this is the correct syntax, for range attribute no need to write down to. It will take range according your bit vector.
'range operator returns whole range of std_logic_vector hence no need to specify 'downto x'.
Which synthesizer you are using ?
Added after 1 minutes:
I_b'RANGE
you can use different attributes for that
for i in I_b'RANGE loop
if range of I_b is 7 downto 0 then you can use
for i in I_b'high downto 0 loop
for i in I_b'left downto 0 loop
if range of I_b is 0 to 7 then you can use
for i in 0 to I_b'high loop
for i in 0 to I_b'right loop
