Why interruption occurs in the phone when I touch a metal?
elmolla
Full Member level 2
Full Member level 2
Why when I open my PC's case or any metallic part and touch it with my hand or with a screw driver I hear this low noise sound? Try it :)
I've posted this already in a previous post as a reply, but no one replied, I think it was agains the rules, so here is the question again!!
hermin
Full Member level 2
Full Member level 2
maybe no one knows the answer...even I, i just think that it has something to do with your body's conductivity,
neoaspilet11
Full Member level 5
Full Member level 5
Cebu, Philippines
Maybe its the humming sound produced in the transformer. Transformer always do that! Try to open a power supply and you can hear a low volume metallic sound. At this moment, I open my printer's power supply and it does produce a soft metallic sound. :)
elmolla
Full Member level 2
Full Member level 2
Re: Why interruption occurs in the phone when I touch a meta
No NO!! You got me wrong neoaspilet11 :)
It happens when I'm speaking in the phone! :):)
Sceadwian
Full Member level 3
Full Member level 3
Sounds like there is something wrong with your home's telephone system, it might be grounded improperly or there's a ground loop with the power system's earth ground.
elmolla
Full Member level 2
Full Member level 2
Hi Sceadwian,
Can you please explain it more?
Sceadwian
Full Member level 3
Full Member level 3
I'm not a telco technician so I really can't explain more, I was just makeing a rough guess, you'd have to contact your local tele;phone company.
hr_rezaee
Advanced Member level 3
Iran-Mashhad
I think your PC is not grounded there for you have noise in your phone when touching it. it may be 50Hz (60Hz) noise.
