In situations like this you can simulate a simple network like a LC filter or a resistive network and see if your simulation results match the hand calculations of the simple network. This will tell you if it is the program at fault or if you did not enter the file for the more complex network properly or if the models for the more complex network are not accurate.
The network can be as simple as a shunt 25 ohm resistor or a capacitor between the 50 ohm source and load.
I want to write a netlist of an LNA UMTS but I have a probleme how I can define term1 and term2 because I haven't a Vin in the entrance? Is there another method to define this term without using .NET??
---------- Post added at 13:06 ---------- Previous post was at 13:05 ----------
