I have done an amplifier design by using folded-cascode configuration. I found that the supply voltage for folded cascode is about 0.6V, however when the same amplifier by using cascode configuration need 1.8V supply voltage.
Can anyone talk about
1. why folded cascode need MUCH LOWER supply voltage that cascode configuration?
2. What is the minimum supply voltage for a folded cascode and cascode configuration? how to calculate the minimum voltage?
3. Are there any advantages of choosing NMOS-PMOS or PMOS-NMOS configuration of folded cascode?
4. Does PMOS contribute less noise or any else advantage to put at second stage?
Hi
1- because there is no tail
2- it depends on many thing but
it is not good that your transistors work in sub-threshold
3- yes but it depend onmany things
noise, cmfb, next stage
4- if the first stage has large gain, don't worry about noise.
Re: why folded cascode amplifier has lower voltage than casc
if these amplifier work in saturation region, in theory, the minimum supply voltage of folded cascode amplifier is min{(4*Vds,sat),(Vgs+Vds,sat)}, and that of telescopic amplifier is min{(5*Vds,sat),(Vgs+Vds,sat)}. but considering the gain and output swing, the actual supply voltage is larger
oh, sorry, it should be max{(4*Vds,sat),(Vgs+Vds,sat)} and max{(5*Vds,sat),(Vgs+Vds,sat)}
i assume the transistors work in saturation region, and i also consider the bias circuit including a mirroring MOS and a diode-connected MOS, the supply voltage should make these circuits work well
I am just wondering what you mean by max{(4*Vds,sat),(Vgs+Vds,sat)}. Since you have two values, so are you refer the supply voltage is in the range from 4*Vds,sat to Vgs+Vds,sat? By the way, what is telescopic amplifier?
for max{(4*Vds,sat),(Vgs+Vds,sat)}, it refers to the larger value, for example, (Vgs+Vds,sat)=0.58V is larger than 4*Vds,sat=0.2V, so it's (Vgs+Vds,sat), 0.58V.
for telescopic amplifier, in your situation, the results is same
in output stage of the folded cascode amplifier, four transistors stack together, the supply needed is 4*Vds,sat for them working normally. considering the bias circuit consisting of a mirroring MOS and a diode-connceted MOS, the supply needed is Vds,sat+Vgs. the two value may be not equal, so we take the maximum value for the whole circuit working well
FYI, my folded cascode is just a simple folded cascode comprise of one NMOS (input) and one pMOS (output) with a diod connected NMOS to supply biasing voltage to input NMOS. Therefore should i change the expression to MAX{(1*Vds,sat),(Vgs+Vds,sat)}?
From simulation for input NMOS, my Vgs=0.54V and Vds,sat=0.04V. So does my maximum supply voltage is equal to Vgs+Vds,sat=0.54+0.04 = 0.58V?
Hi i have attached my schematic. Please kindly advice how is the calculation to get the maximum supply voltage. Because i get the VDD = 0.6V, but can't figure it out the reason behind it.
indeed, your circuit differs from that i think. it's a circuit related to RF? i'm not familiar with this type of circuit, sorry.
look forward to others' reply
