Re: phase...
It depends on the gain figure of the opamp which you didn't attach, but as the phase figure says you have a zero near the first pole of the circuit (a pole-zero doublet) and if they are close to each other, the time domain behavior would have some problems.
Usually, a doublet arises from mismatches in pole-zero compensations due to process tolerances, or is caused by the frequency limitation of current mirrors when they are used for a differential-to-single conversion, or it comes from the feedforward capacitor in a voltage follower. The presence of a pole-zero doublet does not appreciably affect the frequency response of the closed-loop amplifier, but it can greatly modify the time response.
Nevertheless, pole-zero doublets can be used for compensation of OTAs [1], and also in audio applications in which a large gain is required without having a excessively large unity gain bandwidth [2].
[1] Analysis and compensation of two-pole amplifiers with a pole-zero doublet Palmisano, G.; Palumbo, G., TCAS1 1999.
This paper is here:
[2] A High-Linearity 50-Ck CMOS Differential Driver for ISDN Applications R. Castello et al., JSSC 1991.
I have attached this paper.
