Why do you think that 6.8nH series inductor will increase the "Insertion Loss" ?? OK, there will be a small insertion loss due to this inductor but not 1.8dB.
I believe you have confused Insertion Loss and Gain Reduction because of Noise Matching and Gav Matching.The difference can be 1.8dB between Noise Matching and Gav Matching but it doesn't mean the 1.8dB will be inserted between input and LNA.
Thanks for your reply. My thought is as below:
1. According to Friis formula :
For the total noise figure of RX path,
the individual noise figure of these stages posterior to LNA can be ignored because they have gain in their denominator.
For example :
The RX path has 4 stages
Stage1 : NF = 1dB, Gain = -1 dB
Stage2 : NF = 0.85dB, Gain = 16 dB
Stage3 : NF = 1dB, Gain = -1 dB
Stage4 : NF = 2.6dB, Gain = 64 dB
Thus, its RX path total noise figure = 1.97(dB)
Nevertheless, if we just add the noise figure of stage1 and stage2 together:
1dB + 0.85dB = 1.85 dB
The result approximates the previous calculation (1.97dB)
Thus, if the gain of LNA is large enough,
RX path total noise figure = total insertion loss prior to LNA + LNA noise figure
As for your question:
1. Due to the character of the 6.8nH inductor itself, it has about 1.9 dB insertion loss@ GPS frequency(1575 MHz).
Ideal Model Simulation : 1.679 dB
Actual Model Measurement : 1.962 dB
2. Because the series inductor is at LNA input,
As mentioned above,
Thus, its 1.9dB insertion loss increases RX path total noise figure 1.9dB as well.
3. Indeed, the series inductor can reduce the noise figure of LNA.
Again, as mentioned above,
Thus, RX path total noise figure reduces as well.
4. According to point2 and point3, we know that the series inductor can increase and reduce RX path total noise figure simultaneously.
As a result, if sensitivity improves,
the noise figure of LNA must reduce more than the insertion loss of the series inductor at LNA input.
For example:
Insertion loss = 1.9dB, LNA noise figure reduces 2dB => Sensitivity improves 0.1dB
(1.9 – 2 = -0.1, it means that total noise figure reduces 0.1dB)
Otherwise, the sensitivity degrades.
For example:
Insertion loss = 1.9dB, LNA noise figure reduces 1dB => Sensitivity degrades 0.9dB
(1.9 – 1 = 0.9, it means that total noise figure increases 0.9dB)
Is my thought incorrect?
If yes, what’s the blind spot?
Thanks a lot~!!
