Here I've got a chip which has power suply pin VDD of 3.3v and 2.5v at the same time. What does it needs both of them? Is it that they will used to directly drive the drain and source of the EFTs (Field Effect Tube)respectively in a CMOS ASIC chip? And what voltage will logic "1" or "0" will be represented as? Tanks a lot!
This is done where there are several sections. The 3.3 V section interfaces with the outside world. The 2.5 V section has lower breakdown transistors that can run faster.
In this chip powered by 3.3v and 2.5v at the same time, which will used to directly drive the drain and source of the EFTs (Field Effect Tube)respectively in a CMOS ASIC chip? I mean, what voltage will logic "1" or "0" will be represented as? Tanks a lot!
Hi
this multivoltage scenario "can be" just one of the guidlines followed in order to reduce the power consumption. multiple voltage domains concept asks for higher voltages for timimng critical path vallyes and lower voltage regions for timing non-critical paths.
Else this can be because of the dependence of the peripherals (operating onn higher voltages) interacting with the chip and the chip operating at lower voltages.
there can be other reasons also.
I hope it helps
regards
Assumed 2.5v is used to drive chip core, then in order to drive the drain and source of the FETs (Field Effect Tube)what voltage is needed respectively in CMOS logic? I mean, what voltage will logic "1" or "0" will be represented as? Tanks a lot
It's not strange. Maybe you shall investigate the chip and find out each supply's aim.I once met a chip having four supply,1.2v,1.8v,2.5v,3.3v. The 3.3v is for TTL interface,2.5v is for lvds,lvpecl interface,...
now days devices use different voltage for the core, i.e the digital part is fed from 1.2 - 2.5v and i/o buffers/drivers voltage which is generaly 3.3v that is used to connect to the outside world (other devices) in lvtll\lvcmos levels.
the represetntation of '1' and '0' depend on your specific design. the voltage level depends on the threshol voltage that you use(.low VT, standard VT or High VT.) .
Power disipation is serious problem for today high speed chips (processors, graphic accelerators, fiber optic interfaces and high speed, high densty CPLDs).
For CMOS devices Pd~f*V*V. When you reduce core voltage you can use much higher working frequency at same power dispation.
But problem is how to interface chip with outside noisy world. With dual voltage one for core and one for IO pads you can get much higher working frequencies for same power disipation.
different region have different voltage and 1 or 0 is different voltage in different region and there is a convert different region, we know Multi-voltage is more complex but save more power in high speed chip
If u really get the chip design in a formal delivery,
U could trace the power pads and check what they are supplying!
Normally, there should be some doc to discribe it.
