saeddawoud
Full Member level 3
Why do we use the quantization process? and what is the motivation?
when u get sampling result, what will u do to it?... Answer is u will quantise it.. so if u are using suppose 3 bit quantaization, u will try to give a 3 bit (0 to 7) code to each sample. then using these 3 bit codes, u can make ur original signal too.saeddawoud said:Why do we use the quantization process? and what is the motivation?
