hi:
I use the coreConsultant to handle AMBA bus IP, but why the coreConsultant can't generate the readable verilog file(just like binary code).
Thanks for any reply
clive
but if i got the ecrypted codes, can i use them in the simulation tools (e.g modelsim or NC-verilog), how can i do that?
thank you again!!!!
clive
en~~, I have another question, if i want to add the verilog codes which writed by myself into the project which created by coreAssembler to build a big system, can i do that? does that need more license?
coreConsultant can also generate what is called a gtech representation of the core. This can be used for simulation with any simulation tool. You will have to have the Synopsys gtech libraries to do so. Gtech is in a netlist format fyi.
To generate readable rtl, you need the core's source license.
Raghu,
Why not use Google to look for such general doubts - it is for your benefit - will get answers much quickly. Here is what my google search revealed:
