description control signal dram
Hi all,
I have one basic doubt in DRAM.
As we see in DRAM, all command & control signals
Row Address Strobe
Column Address Strobe
Output Enable
Write Enable
are active low. What is the reason for this?
Logically it proves to be advanatgeous to be active high, as logic high voltage need to be given as and when required and is power saving.
Same is the concept when we notice, many microprocessors have active low reset.
Please answer my doubt, if anyone knows it.......
If any one have some good material on memory, (DRAM, SDRAM, DDR technology), can you please post the same?
Thanks,
sita
