kevinj
This is a circuit from mini*circuits. You can get any phase from 0 degrees to 180 degrees by applying 0V to 15V at the control input. Put your signal at the input and it will be phase shifted at the output. The device works from 700MHz to 1GHz.
The black things are varactors(not sure what range is) but they can operate from 0V to 15V.
The blue things with the red dot are inductor (8nH).
There are resistors (202 marking)
Caps are small.
Questions : there are 2 transformers, why? Why not just 1? Are they baluns? Does anyone know how this circuit works?
The windings are all in the same direction. There ratio is 4:4.
In the first picture there are components circled. That's because they are coupled together to act as the transformer. The yellow are coupled to each other and the red are coupled to each other. There coupling factor is 1.
If you look closely at the 3rd picture you'll notice that they switched the red and the green wires. If they didn't do this then they would have a different layout, but I don't think that would matter much. If there is another reason let me know. Thanks.
Caps are small.
