Why are select layers used in layouts?
p_shinde
Full Member level 5
tokyo
Select layer in layout
hello
anyone pls tell why is select layer is used in layouts, its urgent
thanks you
Prasad
Re: Select layer in layout
hi,
what's the select layer, a tech layer or layer selected ?
Hi
Select layer is used for protection. Usuall P-diffusion itself is a select layer i belive.
in our diploma we used to do in this manner
P+ diffusion then surround it with P -select and then N-well thats for P transistor
similarly for N
now why we use P-Select?
thank you,
Prasad
i think select layer means active region for your N transistor, but do not have corresponding technology step.
According you said I consider that your select layer is PPLUS and NPLUS in Mask layer.
This layer is for distinguish N+ or P+ active when manufacture.
