dear everybody
i am studying, practicing design of VCO , and i know the parameter KVCO is very important. i also know that , every the transfer curve of KVCO should be a line .
if it is not a line , that vco is nonlinear .
so i wonder that , in theoretical. what reasons can make vco become nonlinear ? and how can fix this problems ?
All the process variations, supply and temperature variations add to the system non-linearity. List is still broad with second order effects.
For example, VCO stage gain vary with process, supply and temperature, and this gives the non linear effect to the output frequency.
You can make stage gain independent of process ,supply and temperature variations. You can use band-gap voltages for reference and PTAT current to cancel temperature effect.Still you need to use trimming and much more other methods to cancel this.
