[SOLVED] while loop is not working
thannara123
India
seems while loop condition is not entering
#define BUTTON_H_
#define LEFT_S       PINC&(1<<2)
#define RIGHT_S      PINC&(1<<3)
#define UP_S         PINC&(1<<4)
#define DOWN_S       PINC&(1<<5)
#define OK_S         PINC&(1<<6)
/* Function Key Value For UP_Down Key */    void UP_Down_Keyvalue(struct menu s1,int a,int b)
    {  int ch,lower,upper;
                    [COLOR=#ff0000]while(OK_S)  //[/COLOR]
                           if(UP_S)
                                  while(UP_S);
                                  LCD_Clear();
                                  LCD_DisplayString("came to 1");
                                  DELAY_ms(1000);
                            else if(DOWN_S) // down
                                  while(DOWN_S);
                                  LCD_Clear();
                                  LCD_DisplayString("came to 2");
                                  DELAY_ms(1000);
int Key_pressed(void)
    while(1){
    if (LEFT_S) {  while(LEFT_S);return 1; }
    if (RIGHT_S){  while(RIGHT_S);return 2; }
    if (UP_S)  {  while(UP_S); return 3; }
    if (DOWN_S) { while(DOWN_S);return 4 ; }
    if (OK_S) { while(OK_S);return 5 ; }
    else    return 0;
hello,
if PINC contains other value ..
because other PINC at logical TRUE =1
result is allways true
isolate this pin to test it
while(PINC && 64)  //
so
#define OK_S PINC && (1<<6)
hello,
so
Did as said but nothing happens
is touch OK pressed =0 not pressed=64 ?
while(OK_S==64)
// go out the loop when OK_S is not equal to 64
Correct
Incorrect:
while(PINC && 64)
Incorrect:
Use & operator (binary AND) instead of && (logical AND).
                           if(UP_S)...
Only if you simultaneously press OK and one of UP or DOWN keys, will the loop-body be executed.
Was that your intention?
